CryptoWorks embedded box shops.
Leawzkd
MVISON FCIS 9085 Usb Combo Conax and 55cm dish
UK Manchester
Hey everyone,
Im looking for a new sat box to replace my odd looking fta one, ive been look at a CryptoWorks embedded one .
Three questions
Does anybody know any cheap sat site witch sells box like that?
What does this embedded mean?
Do I need a card if its got this embedded installed already?
thanks :-csmile
hoarmey
dreambox 7020
2 x metabox
Live:UK Work:Iraq
for question 1 sorry cant help
q2 and q3 together is easier to answer:
If you are talking completly legit systems then basically you need 2 things to get paid for tele..
You need a CAM (Conditional access module) and a valid card.
The cam is the hardware that does all the magic and the card essentially holds the keys (and hence tells the cam that you can decode signal)
You can get systems with this CAM embedded, basically built into the receiver and it will just have a slot visible for the card It will only take cards belonging to the encryption system that the embedded cam is for.
Alternativly you get a receiver with a CI slot (looks like a laptop PCMCIA slot) and then buy a CAM additionally but thats going off topic..
So either way you need a paid for card.
Just make sure you want cryptoworks as there are many others and differant packages use differant encryptions.
Hope that helps a bit
Leawzkd
UK Manchester
Thanks mate thats helped me alot!
