Cup Final Match??
stuntbelly
Tm1500ci, dragon cam, art card 80cm duel lnd fixed dish hotbird and Astra. 28" w/s tv
Sunny West Kirby, Wirral
Does anybody know if the Liverpool vs Chelsea match ii on either hotbird or astra1. If so what channel..
stuntbelly
arfurdaley said:
:)Hi, its on DSF (Sport) on Astra 1 FTA and Sport Italia on Hotbird m8
I don't believe what happened.. 1-1 at full time and DSF decide to show another match instead of showing extra time .....I had to listen to the last half hour on radio 5..
We laughed about it after a few more beers but the tension you could of cut with a knife....
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Yes, crap wasn't it. I switched to TV Sport on 1W (FTA).
DSF have done that before. I always have a backup plan if at all possible.
Unfortunately, it was only the extra time that was worth watching :(
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
well, I think both of you used the wrong station, should have watched it on ERI TV on 26/ I always check this funky little station as they always keep the original audio. They showed the whole lot...
By the way, me beeing organisedf and all, I usually set up a favourite bouquet called "temp", and I make sure it has all the stations in it that show the games, so I can quickly switch if there is a problem. Use dreamuplan, prepare before game.....
BGonaSTICK
Brighton
Unfortunately, I can't get further east than 19.2... :(
T_G
So you can't even get UK TV on 28? What is blocking your view?
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Drogba has told everyone the PL is Chelsea's. Is he right?
BGonaSTICK
Brighton
Jimbo - Mmmm, not just yet.... :)
T_G - My own house!
I have a S*y dish as well, but my motorised is hidden down the side of my house, out of sight, and out of the wind.
Also have a 1.1m Triax, but it usually lives in the shed.
Only comes out when it's not too cold to balance it on my tyre-mount for two hours!
T_G
Well, you might have to rethink if only showing on ERI....
