DAB dx from the UK
SimonE
Gloucestershire, UK
With an RSP1A SDR plugged into my PC and my 5 element DAB aerial, these are the transmitters I have received here in the UK this year. I use a program called QIRX on the PC. Tropo propagation doesn't occur as often as for the FM broadcasts but still happens. France and Germany are late to bring DAB to their audiences and, of course, using DAB+ with reasonable bit rates. My best dx was 5C DR Deutchland from Casekow 1109kms away. The other jpg is a freeze frame while receiving LeMans ET on 7A three days ago with audio.
rodscha
DAB+ here has a lower strenth than FM ,it s stopped by village houses along the road when FM gets through perfectly. It seems to cover only 20 kms... what s the use of DAB+?
MrDish1
Delta Star
Qth:Aalten
What kind of program is that ?,that : called QIRX
SimonE
Gloucestershire, UK
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Some impressive catches Simon! Presumably this will get more tricky as more Small Scale DAB transmitters come on-line in the UK transmitting in the 7-9 channel ranges.
victor64
Octagon SF 8008 combo UHD
Timisoara, Romania
How do you obtain the map in QIRX ?
SimonE
Gloucestershire, UK
In QIRX look at the top and find the home button. two to the right is the show map button.1735634015708.png
To make somebody money manufacturing ever more useless boxes.
The coverage has not changed much in years, many countries have already rejected DAB/DAB+ for superior mediums
SimonE
Gloucestershire, UK
Yes timo, I have had some SS DAB come on and block dx but in the UK the main services are on channels 10, 11, and 12. 13 is only used in Scandinavia and 5A to 10A is mostly clear except for 8B, 9A and 9B where I have local SS DAB muxes.
