bmathieson
- Dec 9, 2009
- Age
- 76
- Sky+HD; Denon 5.1 amp, etc. 2x wireless laptops & 1 static pc feeding into Be ISP.
- Plymouth, Devon, UK
I have recently moved to Plymouth from Scotland and I set up my DAB receiver in exactly the same way as before: I have a 3 element aerial in the loft space pointint in the same direction as all the tv aerials are pointing around here (towards the main transmitter at Saltash, I believe). I have it in horizontal position.
Here's the problem: I have used a UHF/VHF Antiference splitter to run the signal down a single cable before unsplitting it at a pair of sockets in my living room. This worked before, first of all with my FM aerial & radio years ago and more recently with my DAB aerial & radio in Scotland.
Currently, I am getting absolutely no signal from any station/group on DAB. Is the problem the position of the aerial or the use of the FM/UHF splitter, in which case, what should I be doing?
Your help would be appreciated.
