patmos
- May 28, 2007
- Age
- 64
- STRONG SRT-4910+,SunRay4HDse,TBS5922, 2.4M P.F Apstar7(76.5 DEGE), 120cm dish PAS 10 Ku( 68.5 DEGE),3.0M Mesh Motorised dish on arc (AM44 (11DEGW) to AM33(96.5 DEGE),150 cm dish W3C(16 DeG E)+ side LNB Ew2A(10 DEGE),90cm W4/W7 (36 DEGE)
- Mauritius
I wanted to see how gbox works on SS2 PCI. But i'm stuck with UDP port forwarding. I've forwarded port for utorrent(TCP) and it works. I forward port 2077 UDP in my router Sagem Livebox 43b5 and put exceptions in my firewall(both windows and Kaspersky)but no udp seems to work. When I enable any TCP port it does work. Please help what could be the problem. I run a small prog TCPvieWer.My pc is set to a static ip 192.168.1.43 and I'm thru dyndns host. Here is what it's look
svchost.exe:900 UDP user-28bc844c4e:1900 *:*
wltuser.exe:4752 UDP user-28bc844c4e:3219 *:*
WINWORD.EXE:5476 UDP user-28bc844c4e:3126 *:*
svchost.exe:476 UDP user-28bc844c4e:1048 *:*
lsass.exe:1796 UDP user-28bc844c4e:isakmp *:*
OUTLOOK.EXE:4948 UDP user-28bc844c4e:3111 *:*
svchost.exe:476 UDP user-28bc844c4e:1047 *:*
System:4 UDP user-28bc844c4e:netbios-ns *:*
svchost.exe:476 UDP user-28bc844c4e:bootps *:*
svchost.exe:476 UDP user-28bc844c4e:1100 *:*
svchost.exe:476 UDP user-28bc844c4e:ntp *:*
mDNSResponder.exe:2008 UDP user-28bc844c4e:1025 *:*
System:4 UDP user-28bc844c4e:netbios-dgm *:*
KService.exe:720 UDP user-28bc844c4e:1948 *:*
mDNSResponder.exe:2008 UDP user-28bc844c4e:5353 *:*
svchost.exe:476 UDP user-28bc844c4e:bootpc *:*
mDNSResponder.exe:2008 UDP user-28bc844c4e:51224 *:*
svchost.exe:476 UDP user-28bc844c4e:domain *:*
lsass.exe:1796 UDP user-28bc844c4e:4500 *:*
System:4 UDP user-28bc844c4e:microsoft-ds *:*
iexplore.exe:268 UDP user-28bc844c4e:2358 *:*
jqs.exe:240 TCP user-28bc844c4e:5152 localhost:3503 CLOSE_WAIT
iTunesHelper.exe:956 TCP user-28bc844c4e:1039 localhost:27015 ESTABLISHED
KService.exe:720 TCP user-28bc844c4e:1035 localhost:1036 ESTABLISHED
KService.exe:720 TCP user-28bc844c4e:1036 localhost:1035 ESTABLISHED
KService.exe:720 TCP user-28bc844c4e:1037 localhost:1038 ESTABLISHED
KService.exe:720 TCP user-28bc844c4e:1038 localhost:1037 ESTABLISHED
PCSuite.exe:296 TCP user-28bc844c4e:1058 localhost:1110 CLOSE_WAIT
mDNSResponder.exe:2008 TCP user-28bc844c4e:5354 user-28bc844c4e:0 LISTENING
System:4 TCP user-28bc844c4e:netbios-ssn user-28bc844c4e:0 LISTENING
System:4 TCP user-28bc844c4e:microsoft-ds user-28bc844c4e:0 LISTENING
AppleMobileDeviceService.exe:1924 TCP user-28bc844c4e:27015 user-28bc844c4e:0 LISTENING
For UDP i see only *.* for remote address. Any help is welcome. I'm now doubting whether it is not blocked at the ISP level.
