Digitalb Card in Infinity Phoenix USB
chavo
Liverpool, England
Vu uno, VU Duo2, sky dish, 2 zone 2 dishes for 19.2 and 23.5. Satlink meter, rover STCeu meter. Tripod with a dish for messing around.
North West England
hi all,
I have just built a PC server to split my digitalb card between my front and back room. the server is running with cccam 2.09 in clarkeconnect 4.3. i tried 5 but had problems, i also had problems with newer versions of cccam. 2.09 was the latest version that worked with no problems. so all my boxes can see my server but i cant get the card working in the infinity.
What is the Mhz? 3.58?
Mickha
North West
That sounds like the Phoenix mode, on the programmer, for programming cards, you can switch between 3.58 Mhz and 6 Mhz.
The Infinity/Phoenix USB requires 2 cables, to use phoenix mode, the USB and Serial cable, connected to the PC Com port.
_http://www.infinityusb.com/default.asp?show=productsdetail&ProductID=7
chavo
Liverpool, England
North West England
Got it running i just took the card out and re inserted it and now it appears. very happy!!!
thanks
ps running it at 3.58.
