DIGITALB - Loss of transponder signal
dazmaul
Digitalb
Satcatcher III
Stockport, UK
Help!
I am a subscriber to the Digitalb Gold package on the Eutelsat 16E satellite. My system has lost the signal to the transponder which has the football channels on (11449 H 27500). I thought I had lost the signal to the entire satellite but I can still get the movie channels.
Have they moved the channels to a different transponder?
It was working up until last weekend - and nothing has changed.
I have a sneaky suspision that my box has reset itself as the language was set to Dutch when I turned it on this weekend.
My box is a Satcatcher Voyager III.
Any help/thoughts much appreciated.
mhku
TM Nano ~ sg2100
Midlands
Have you contacted the shop you bought the box/ card from?
Or _http://www.satcatcher.co.uk/home
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
dazmaul said:
Help!
Hi, I only have the movie package, but I have just checked the transponder you mention and it is as strong as ever.
When you say you have lost the signal, is that what you really mean?, or have you just lost the picture. Are you getting poor signal quality on the transponder? Have you tried re-scanning the transponder?
Have you checked the CAS settings on the card? to check that your sub is still in force.
dazmaul
Digitalb
Satcatcher III
Stockport, UK
Thanks for the response guys. I have solved the problem, I had no signal at all to the transponder (11449), as in 0%, but I have rebooted the system and rescanned the satellite and I now have the channels back. They are on the same transponder as before so I do not know why it would not pick them up. WEIRD.
Thanks again.
