Direct 8 19E
Direct 8 (D8) (France)
Astra 1L
12.551V
Sr 22000
FEC 5/6
FTA (MPEG2 4:2:0)
Entrtainment channel. Clint Eastwood film at present (French audio). Bound to go encrypted soon, as on a couple of other satellites (5W, 13E)
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Encrypted now.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
D8 left 12551V, D17 - on. New frequency of D8 - 12402V/27500, FTA now
C0re
Ede
VU+ Solo SE
D8 moved to 12402V and has been FTA for a while there. But it's encrypted now or do you have a CanalSat subscription?
No problem opening with my Diablo CAM. Maybe working with various emulators too.
C0re
Ede
VU+ Solo SE
I only have a FTA tuner (1 for DVB-S and 1 for DVB-C) with a UPC C+ CAM (Nagravision for cable) and I can't get a picture. It says: "Scrambled Signal".
Adam792
Cheltenham
They've basically 'swapped' D8 and D17 over (since they've been owned by Canal) so D8 can have D17's old 720x576 full resolution slot while D17 gets the poorer 544x576 slot (less bitrate available I'm guessing). D8 went full resolution in the 12.551 slot a few weeks before the swap but they obviously didn't think the capacity was enough to keep it that way and have a decent enough picture.
It seems the encryption's swapped too with D8 now encrypted and D17 FTA. I miss Europe 2 TV (D17 years ago)!
