Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
DISH SETUP: Single sat, Multi-Sat & Motorised
diseqc switch without diseqc switching receiver
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="FRAZER" data-source="post: 124056" data-attributes="member: 175135"><p>Thanks for the advice; I now (nearly) have it up and running. I too have found that the disecq switch stayed fixed to the last lnb being used by the DVB-s card rather than reverting to lnb1, even though the motor receiver is the master on the priority switch. When I get the chance, though, I shall try it again with the computer actually switched off after using lnb2 to see if it makes a difference.</p><p></p><p>Thanks again,</p><p></p><p>Frazer</p></blockquote><p></p>
[QUOTE="FRAZER, post: 124056, member: 175135"] Thanks for the advice; I now (nearly) have it up and running. I too have found that the disecq switch stayed fixed to the last lnb being used by the DVB-s card rather than reverting to lnb1, even though the motor receiver is the master on the priority switch. When I get the chance, though, I shall try it again with the computer actually switched off after using lnb2 to see if it makes a difference. Thanks again, Frazer [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
