DiSEqC Switch
mimoace
Showtime
with Showbox
Middle East
Dear Experts...
Can any one help me if the terms (DiSEqC A).. (DiSEqC :cool: differs from (DiSEqC 1) .. (DiSEqC 2)... in the operation...
My receiver show DiSEqC A and my switch shows DiSEqC 1. Is there any problem working together...
Regards
v9oly
Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams.
South West
Don't think so mate, but it would pay to name your receiver in your signature strip, to be sure.
regards,
Ollie
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
mimoace said:
Dear Experts...
Regards
One way to find out, Does it work?
mimoace
Showtime
with Showbox
Middle East
Thanks Friends
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
Different receiver have different naming convention:
For DiSEqC-1.0:
Official naming convention:
A-A
A-B
B-A
B-B
Non-Official naming conventions:
or
B
C
D
Do not mix up DiSEqC-1.0, 1.1, 1.2 and 2.0:
1.0: allows switching between up to 4 inputs
1.1/2.0: allows the usage of cascading switches with up to 16 inputs (or even more)
1.2: allows the use of rotor's
Cheers,
vma
v9oly
South West
Don't you mean 1.1/2.1 for cascading switches?
Regards,
Ollie
vma
Portugal
Portugal
You are right.
Actually it is like this:
1.0 -> simple commutation of up to 4 LNB's
1.1 -> complex commutation using cascading switches
2.0 -> simple commutation of up to 4 LNB's AND RETURN PATH
2.1 -> complex commutation using cascading switches AND RETURN PATH
With "Return Path" I mean a bi-directional communication, i.e. the switch can send a status information back to the receiver. I have never come across 2.0/2.1 compatible switches or receivers, so I lack further knowledge about that.
Anyway, the complete DiSEqC-Spec's can be found here: _http://www.eutelsat.com/satellites/pdf/Diseqc/Reference%20docs/bus_spec.pdf
Cheers,
vma
Robbo
Retired Mod
Gravesend,Kent,UK
Here's an example of a 2.1 ( and 1.1) switch
_http://www.spaun.de/?lang=en&modul=products&product=871434&productname=SUR211F
