bodge
I'm in a fringe reception area and am ín the process of buying a secondhand 2.4m dish with the aim of picking up Astra 2D. I am not sure if this type of dish will be any good for the job. Any comments/advice ?
Likvid said:Your dish is a 2.4m Winegard Pinnacle dish, one of the best dishes "ever" made way back 10-15 years back.
It was one of the few dishes that was in mesh that performed like a solid Ku-band dish.
However, you need the appropiate feedhorn for it as the dish got a f/d of 0.25 and there is only one feed for it and that is the Seavey Engineering.
I installed several of these dishes and they perform very good due to the low f/d and high tolerance.
Keep it and get the right feed if you don't already have it.
The dish got a gain at 11.3GHz of 46.8dBi and it lives up to it, i performed some tests on it long time back(15 years) and it performed like a very good SMC(glasfibre) prime focus dish, think it was Prodelin 2,4m i compared it to.
PM me if you want to know more about it.
Can you take a picture of the feedplate as well? then i can tell you if it is Seavey or not.
