leejohn02
- Sep 30, 2024
- Age
- 40
- Tracvision r45l
- Esssex
New here and wondered if anyone can help, i've tried doing it on my own but really struggling, i've managed to change the LNB as the model is old and can't get support from tracvision because the model is no longer supported. I can change the :LNB if i need to but i want to first check everything is working. I've connected to the serial poirt on my board and used hyperxterminal and can see the satelite being searched for are astra 1 and hotwire, i know this needs to be changed to Astra 28.2E for freesat but cant find the information to manually edit the satelites. I can add custom user satelites x 2 and have sucessfully got to this step, but its asking me for certain info that i cannot seem to obtain myself with a weeks worth of google searching i'm at a loss and need help, its currently asking for the following information on the satelite in order to pin point it.
Longtitude
East or West
decoding type (0 = test, 1 = DSS-A, 2 = DSS-B, 3 = DVB )
frequency in MHz (either 00000 or a range from 10700 - 12700)
the satellite transponder symbol rate in Mbit/second (01000 - 29999)
the FEC code (e.g., 12, 23, 34, 56, 67, 78)
the satellite network ID in hexadecimal format (0x####)
the LNB polarization (v = vertical, h = horizontal, r = right, l = left)
the LNB down conversion frequency (l = low, h = high, u = USA)
Longtitude
East or West
