DIY Satellite and TV Ariel
mdemetri2
None at the moment!
UK, Leeds
Hi All
Hopefully someone can help me here. I have just bought and house and in the early stages of gutting it out. I plan to have tv in three room (living room, kitchen and master bedroom).
I want to lay all the cabling myself for the Sky and TV and was wondering what cable I need, is the cable the same for each? Also I plan to get Sky+ (I believe this uses two cables?).
I will then get someone to come fit the actual ariel, then when I have moved in get Sky round to filt the dish (as this included in the packaged when you sign up obviously).
So in short, what cabling do I require so that i can put it in, hide it in walls etc and plastered so its all nice a neat........
Thank you!!
2cvbloke
Near Pontop Pike, Co. Durham
All you need is CT or WF100 cable for both, CT being air-spaced and WF being foam filled. I believe Maplin & B&Q stock both types... :)
If you're cabling from scratch you might think about combining your TV and satellite signals with a multiswitch so that you only need to run one cable to each room and use a triplexer to split the signals at the room end. You could even run 2 cables to each room and use a quadplexer so that you're ready for $ly+ (or even the new Freesat service?).
It's a bit more expensive but you have greater flexibilty.
v9oly
Dreambox 500S & 7020s. Technomate 9100 & 1500. Force frontier fixed, Raven 90 fixed, Triax 90 motorised dish. Diablo & dragon cams.
South West
If you're going to get through a lot of cable it may pay to enquire at an electrical wholesaler, I saved quite a bit this way, they may have the f connectors also.
Regards,
Ollie
Better to go via an aerial wholesaler, they are more likely to have the better quality cable.
mdemetri2
None at the moment!
UK, Leeds
Hello everyone,
Thanks to those that responded with their comments.
I have bought a 100meter length of WF100, all the F connectors and ariel screw into F connector connections (if that makes sense). I will use this cable for both tv and satellite (SKY+) and will cable it in myself connecting from the main ariel to a 3 way splitter - will see what the signal is like as it may need a booster.
thanks again!
mdmetri2
You only need the aerial to feed the point near the digibox, then if you loop it through the Sky+ box, send it back to the loft and use a TV link compatible amp in the loft to serve the other TVs with terrestrial TV and the output from the Sky+ box. :)
