DMX241 C-band LNB ??
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
was looking around for a high performance C-band dual polarity LNB and saw this new one in the market ...before any thing if any member(s) with experience regarding this LNB....cheers guys
Satcom1
1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver.
Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Chicago
Competitor to BSC421, works good.
pipino
Back from the dead
how better then BSC421?? as i have one ,,do you get a drastic difference or just a cosmetic one :D
Satcom1
Chicago
BSC 421 is a pretty good LNBF. Especially if yours says 13K. Panorama 13K is good. DMX 241 is not better then either. You've got to move up to a Norsat which has extremly stable LO. $$$$
pipino
Back from the dead
what about "Chaparral MicroPak 3G" any reviews about it??
Satcom1
Chicago
For those with lots of $$, Norsat is the lnbf of choice. But then there are people that always buy the most expensive item, assuming quality.
