Dragon loader/Dynamite programmer
BRANKO
HI
i had to wipe my computer and lost my Dragon Loader.
ALso my Dynamite set up 2.5 and jungo drivers 6.21.
including Preditor software.
I had these since 2004 if anyone could please help it would be appreciated.
THX
Mickha
North West
You can get the latest drivers for your dynamite programmer from duolabs, just click on the software link.
The latest firmware for the Dragon Cam is predator 368, if you type predator368 into any search engine you should quickly find it.
Check the Links Section, on the forum, as other members have posted some useful links for software and utilities.
BRANKO
Hi Mickha
Thx for your reply i have the loader fine.
I know where to get 368 from.
But the Duolabs seem to have downloads for the Dynamite CAS and i dont think mine is the cas, or will
that work with this Old programmer i have from 2004.
I'm using prussian 7 card.
Thx again
Mickha
North West
The Cas studio software is supposed to work with the dynamite programmer, it is mentioned in the list.
Try it and if it doesn't work I'll search for some older drivers.
alghazoly
my reciever model is jac 5100
egypt
