Advice Needed Dreambox DM7080 HD 2x DVB-S2 2x DVB-C/T Tuner Linux Combo Receiver
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good afternoon from a sunny Mullion Cove : )
Are any of you gentlemen using one of these or a simlar model ?
Yours truly has been thinking of asking Father Christmas for one of these so that we can use the 4k resolution on our TV.
Apart from a hard drive that came with the set we have no 4k content.
From the esteemed members there are sats out there now with 4k content.
It appears that Technomate have still to launch one or I would have made a purchase, there being a lot of downloads available for Technomate.
God Bless Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Thank you for the links I will have a read.
This is the eBay advert I copied from, the receiver has 4k on the front plus I translated the spec and that confirmed it.
Dreambox DM7080 HD 2x DVB-S2 2x DVB-C/T Tuner Linux Combo Receiver SOFORT LIEFER 4044845708017 | eBay
A lot of equipment sold now uses very similar model numbers, making it difficult to be sure what you are looking at.
Spiff
Ghostleader
Glasgow,ish!
Mutant is NOT an original Dreambox receiver. The title is misleading.
Your dam tooting its misleading, its a completely different make & model! lol
Sent from my thl_T7 using Tapatalk
Mickha
North West
The VU+ Uno 4K is now available, and soon the VU+ Ultimo 4K should be available.
Archive7
Wonderful.
I think the UNO is limited can't have both DVB-S2 and DVB-C/T/T2 which is what Spiff wants.
The ULTIMO is too expensive for me ATM. The SOLO 4K has been around for a while so perhaps it has some support already.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
With the same model number ?
Given that spec below : - in English
Right at the bottom I have coppied the eBay Item specifics Condition which says 1080 it could be an error as far as that goes but the rest of the sec looks OK to me.
It mentions Usals but not a blind scan ?
EN" lang="EN">Mutant HD51 4K UHD SAT Receiver 2xDVB-S2 Tuner 2160p Linux E2
The latest Mut @ nt HD51 4K satellite receiver is finally available from us. The heart of the new HD51 4K receiver is the latest BCM 7251s DMIPS CPU: 10500 DMIPS processor. Now you can finally switch channels under 1 sec. The picture quality is absolutely remarkable with 2160p 4K Full Resolution. IPTV lists are processed / reproduced by the HD51 receiver. Experience Ultra High Definition (UHD) TV with your new Mutant HD51 4k Box.
Technical specifications:
E2 Linux OS operating system
CPU BCM 7251sDMIPS CPU 10500 (2x1700Mhz)
2x DVB-S2 tuner included
SoC 28 nm
Clocking in Mhz 1700
Cores 2
Threads 2
Max. Video resolution 2160p (4K).
H.265 Yes
VP9
4K Youtube Yes.
VP8 - Youtube Yes.
OpenGL ES 2.0
Nand Flash 4096MB (4G:cool:
DDR memory 1 GB
1x Smartcard Reader
1x Common Interface
Tuner changeable yes
2 x Plug & Play Tuner slots suitable for DVB-S2 or Hybrid Tuner (DVB-C / T / T2)
1x USB 2.0 front
1x USB 3.0 rear
LAN (max Mbps) 1000 Gigabit LAN connection
Hard disk yes - 1 x Internal 2.5 "possible and external
HDMI version 2.0
RCA Yes
S / PDIF (Optical) Yes
Display VFD DOT-matrix display
Power supply External 12V
Consumption (FSD) 13,1W | 7,1W | 0.5W
Dimensions (Wt) 30 x 22 x 5
Restart: 27 seconds (tested with OpenATV Images)
New Gui Start: 7 seconds (OpenATV Images tested)
Youtube 4K still needs extra software update, this will appear later.
Delivery:
1x Mutant HD51 4K satellite receiver 2x DVB-S2
1x remote control including batteries
1x external power supply / mains cable
1x HDMI cable
1x Short manual
1x hard disk holder incl. Cables & screws
Item specifics
Condition:
New: A brand new, unused, unopened and undamaged item in original retail ... Read more
About the condition
Audio / Video Outputs: Digital Audio Optical TOSLINK, HDMI, HDMI IN & OUT
Product Type: HD Digital Data Interfaces: Ethernet port, WLAN, CI (Common Interface) slot, USB 3.0
Surround Sound formats: Dolby Digital, Dolby Surround Features: Dual receiver, Free reception, Teletext
Supported DiSEqC levels: 1.0, 1.1, 1.2, 2.0, 2.1 Manufacturing warranty: 2 years
Manufacturer: Dreambox
EAN: 4044845708017 Max. Resolution: 1080p
Archive7
Mutant official website doesn't claim it is Dreambox model.
HD51 4K-HEVC » mutant-digital.net
Funny thing is that they don't have a manual there.
The seller on eBay is misleading with the title.
I believe the Mutant is indeed 4K if this is what you want, but I would recommend to wait until you know exactly what you will get
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Wonderful.
I require just a satellite tuner in the unit as it is to add 4k, I believe there is no 4k on terrestrial TV as of yet.
Spiff
Archive7
Spiff
In that case, take a look at the UNO 4k
It is still a limited receiver compared to the SOLO 4k and the ULTIMO 4k
Please note that the tuner is FBC (Full Band Capture) which makes it possible to watch more than one transponder while recording a channel on a different TP.
VU Plus
blademedia
Sky
The mutant is a good set top box, but hold on, the tuners are plug and play and atm it wont decode s2x, there supposed to be/have brought out a tuner for s2x, but ive yet to find one,
There's another box coming out that does s2x will post link when I find it, whatever you buy make sure it will decode S2x, lots of programmes will be broadcast in S2x in the near future ;)
Archive7
Thanks for mentioning the S2X I learnt something new today.
I am interested in satellite receivers with DBV-S2 FBC tuner and till now I have seen only VU+ and Gigablue offering it.
Are there any other manufacturers?
blademedia
Sky
I don't think Technicolor do retail boxes - but they are one of the largest manufacturers for operators and others.
They bought the STB part of Cisco last year, consolidating their footprint.
We buy most of our IPTV boxes from them.
I think you will struggle to find this as a retail item. :)
You can buy them st1, looked into it before Germany I think was the place I found them, yes they do most companies Bein etc
archive10
The specs says that the SoC is a Broadcom 7251s, and that definitely supports UHD.
(This goes for the Octagon as well)
So it does 4K (more pixels), but the HDR support is limited to HDR10 (better pixels), and, according to BCM, HLG.
However, I have yet to see HLG content play on a 7251s or 7252s. HLG is what is being promoted by the BBC.
Most of the stuff that's transmitted on Eutelsat and Astra are non-HDR (at least was when I cheked in September), so you should be fine.
HDR10 works great with Blu-ray content, as this is what most studios support, and is present in the BCM UHD chipsets, so there are already millions and millions out there.
Even the NetFlix 4K is so far just that, 4K. They have announced HDR, but it's so far very limited.
And of course - there's the bitrate issue. Proper UHD (4K, HDR, extended Gamut, UHD audio) is trending towards 35Mb/s.
For streaming services, this precludes a good portion of customers.
For SAT operators it means you could have had revenue from 5-6 HD channels instead.
And there's still many standards and lots of incompatibilities between content, STB and TV, so don't expect out-of-box operation with anything off the air.
I guess what I am trying to say is: Do experiment and see what is out there, but don't expect the equipment to be future-proof...
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
As UHD is all quite new I wonder about going for something low cost for now like this : -
The sat only version can be found for £113 : )
Ferguson Ariva 4K UHD - Satellite Receiver | Alza.co.uk
Below is data from a pdf of spec on the unit : -
Spiff
BASIC INFORMATION ABOUT THE RECEIVER
1. Main features
✔ Reception of UHD (ultra high definition channels), HD
✔ HDMI 2.0,
✔ Availability of programmable timers
✔ Separate lists of favourite, TV and Radio channels
✔ Quick channel search function (QuickFind)
✔ Teletext and on-screen captions
✔ DiSEqC 1.0, 1.1 and DiSEqC 1.2, USALS
✔ MPEG-2, MPEG-4, MPEG-4 AVC/H.264/H.265 standards
✔ Compatible with DVB-S/S2, DVB-T/T2 and DVB-C systems (depending on model)
✔ Card reader for pay-per-view television
✔ Common Interface (depending on model)
SPECIFICATION
Ariva 4K/4K Combo
1.Main Chip Sets
Chipset Amlogic S905-B, Quad core Cortex A53 @ 2.02 GHz
Flash Memory EMMC 8GB
DDR III Memory 1GB
2.DVBS Tuner & Demodulator
Tuner Type ON BOARD
Frequency Range 950 ~ 2150MHz
Demodulator Mode DVB-S (QPSK, ETS 300 421) and DVB-S2 (QPSK / 8PSK, ETS 302 307)
RF Input Connector F-Female
3.DVBT/T2/C Tuner & Demodulator (depending on model)
Demodulator Mode ETSI EN 302-755 V1.3.1 and EN 300-744 V1.6.1 compliant
Frequency Range 52.5MHz to 866MHz
RF Input Connector IEC-Female
4.TS Demux
Demultiplexer MPEG2/MPEG4
Input Bit Rate Max 100Mbit/s
5.Video
Video Decode
H.264/H.265 HEVC MP@L5.0 up to 4K UHD@60fps
H.264/H.265 AVC MP@L5.1 up to 4K UHD@60fps
H.264/H.265 MVC up to 4K UHD@60fps
MPEG-4 ASP@L5 up to 1080P@60fps
AVS Jizhun Profile up to 1080P@60fps
MPEG-2 MP@HL up to 1080P@60fps
MPEG-1 MP@HL up to 1080P@60fps
RealVideo 8/9/10 up to 1080P@60fps
WebM up to VGA
Video File Format Support *.mkv, *.wmv,*.mpg,*.mpeg,*.dat,*avi,*.mov,*.iso,*.mp4,*.rm,*.jpg,
*.bmp, *gif and others
HDMI Output HDMI 2.0 (video format default @ Auto)
Aspect Ratio Auto, Full screen
Video Resolution 4K@60Hz 4K@50Hz 1080p/i 720p
6.Network
Wi -Fi Built-in 802.11 b/g/n, 2.4G/5G dual band
Ethernet 100M Ethernet RJ-45
7.Audio Decode
Audio Decode Dolby Digital/Digital Plus, MEPG, OGG,OGA,FLAC,ALAC,Ape,M4A,RM, MPEG-1
layer1/2, MPEG-2 Layer II ( DTS passthru)
Sound Mode LEFT/RIGHT/STEREO/MONO
Sampling Frequency 32KHz 44.1KHz 48KHz
8.PVR Function
42
Record
Instant Record and Timer Record
GUIDE Timer Record
Time-Shift Support Auto Time-Shift
PVR Operation
Play/Pause/Stop/Step
Fast Forward/Fast Backward 2/4/8/16
File System Support NTFS, FAT32
PVR Manager Delete recorded file
9.AV Output
Video Bandwidth SD:5.0MHz(-3d:cool:, HD:30MHz(-3d:cool:
Video Impedance 75Ω
Video Voltage Level 1.0 Vp-p
Audio Freq. Range 20~20KHz
Audio Impedance 600Ω
Audio Voltage Level 2V rms(5.6Vp-p)
archive10
Difficult to say without having one.
One thing may be the HW (Amlogic etc), but even more important is the software.
Even though it says Android as OS, this could mean anything from streamlined, smooth sailing to bitchy, buggy no-frills implementation.
As this has no open-iamge support, it is difficult to say how well this would suit an enthusiasts need...
(unless someone can find a revealing review on the web - and not written by the importer themselves :) )
