With the price of a Dreambox Keyboard at about 50 quid plus shipment, I thought it might be cheaper to use a standard keyboard in liason with the remote.
I would like to report that it is possible to use a standard keyboard to type a reply to e-mail messages, when the TuxMail is loaded.
You need to use the remote in order to click on the coloured buttons and other functions.
Connect a standard keyboard with USB plug to the USB receptacle on the back of DreamBox 7000S.
With an extension USB cable you can type while sitting in your TV couch.
Switch on the box and load the Tuxmail.
With the green button, it is possible to edit an e-mail message.
Click the yellow button several times until Keyboard is displayed.
Move the curser to a new line and start typing a short reply with the keyboard.
All the ASCII characters can be typed as if you are typing using a PC.
Also the space, delete, backspace, etc are functional.
The Shift, Alt, Ctrl keys are not functional.
When you are ready to send the reply, click on the yellow button until you see ABC
Click OK and a popup message asks you if you want to send the message
Click OK and the message is sent successfully.
Off course it is better to use a lightweight slim wireless keyboard instead of a leaded one.
Will test this possibilty soon.
The price of a wireless keyboard is still a lot cheaper than 50 quid.
The only problem that I can see at the moment is that if you have a USB stick already for the /var , then you might need a USB hub with several inputs in order to accomodate both the USB stick and the USB wireless receiver.
Update:
It is also possible to edit text files using a keyboard.
For example, if you have Tux Commander, load it and then edit config files or keys.
You need to press OK on the remote in order to enable editting with the keyboard. (The Enter key is not functional in this case)
