Archive-8
With the change in google maps policy regarding api use I have added bing maps to Dump1090.
I didn’t add it personally I just added my existing api key.
I did this to add the key in
cd /usr/share/dump1090-mutability/html/
sudo nano config.js
The bing maps api location is right at the bottom of the config page.
Save it with ctrl + x, and yes.
You pop the api key in right at the very bottom, it has a section for you to add it.
This is my Dump1090
I also added heywhatsthat panorama, I still have some more tweaks to do.
My personal favourite is the message rate at the top of the browser not visible via iPhone browser, it needs a pc to be able to view the rate.
I want to sort the clocks out next.
sudo nano config.js
This is my Dump1090
