DVB-S Application with WMV Support
HB13DISH
Retired Mod
Middle East - Israel
I am looking for a DVB-S PC application for my Nexus-S PCI card, with support for wmv files, play and record.
Tried latest ProgDVB, but it has support only for low resolution files and also causes a lot of problems to my PC, like hanging with the need to shutdown PC with the manual switch, something that I not happy to do.
Thanks for any suggestions. :)
BombedOne
Republic of Georgia
Very unlikely such app to exist...
HB13DISH
Retired Mod
Why not? If ProgDVB can do, it is probable that others would.
BombedOne
Republic of Georgia
You can use dvbdream and stream with it over lan, then capture with VLC and encode in WMV...
HB13DISH
Retired Mod
Just installed latest MyTheatre and it is able to play WMV files according to their help file.:)
Have played a file OK before the scanning of channels in file mode, but after scanning, it stopped working. Need to investigate why.
It is a very good application. Beats ProgDVB for sure.
BombedOne
Republic of Georgia
Yes but by interface clutter it is next to ALTDVB - most weird dvb-s app.
Dvbdream seems to be most user friendly.
HB13DISH
Retired Mod
Thanks, but DVBdream doesn't recognize my DVB-S card and MyTheatre does.
BombedOne
Republic of Georgia
Does your card has BDA drivers? there's universal wrapper for BDA cards for dvbdream. My SkyStar 2HD also does not works directly, but using that wrapper it works ok.
