riccume
- Jul 1, 2011
- Age
- 54
Astra 2 and Hotbird via 2 Quattro LNBs, 9x16 Triax TMP Multiswitch
HTPC with Windows 7 Professional
TBS 8921 Tuner Card
- London
I'm trying to figure out which DiSEqC commands (or Tone Burst?) my TBS 8921 DVB-S/S2 tuner card should send to switch from Sat 1 to Sat 2. Unfortunately I don't have full access to the details of the multiswitch since I live in an apartment building which has recently been wired for Sky and Hotbird; I contacted Triax for the manual but no luck so far. My previous card (Compro VideoMate S350 - I had to change due to BBC HD moving to DVB-S2) was oblivious of DiSEqC and happily tuned Astra. When I tried to do the same with the TBS 8921, it would only pick up Hotbird.
The lay-out is the following:
- 2 Quattro LNBs, feeding Astra 2 (Sky) to the four Sat 1 inputs, and Hotbird to the four Sat 2 inputs (it could be the other way around, this is what the installer told me when contacted but he wasn't too bothered)
- Triax TMP 9x16 multiswitch, which feeds the flats
I've tried with several viewer programs to send DiSEqC signals (Pos A/Osc A, etc.) to the multiswitch and I get Hotbird in Pos A/Osc B, but no Astra. Finally while playing with TVSource I tried the configuration with no DiSEqC signal for Astra ("None" in the drop-down menu) and "Pos A/Osc B" for Hotbird, and it worked correctly!
Can anybody guess what is going on here? This setting looks strange to me... but it works. Thanks!
