dvbdream lnb voltage
portly
Bush freesat hd box, iss 70cm dish,single passion lnb , goodmans GDB15HD freeview box
heathrow
what voltage should an lnb be set to ,dvbdream has set it to 18v as standard. theres no info on the box the lnb came in , its really a cheapo that does a good jobby " premium hd universal ku band lnb"made in korea:-rofl2
Ta Gaz
When you first configure your satellites to use 'Universal' in DVBDream, switching between 13/18V is automatic.
In the Preferencies menu, the 18V option is for bandstacking LNBs as used in some NA LNB setups, not relevant in the UK.
selvam
12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300.
Dear Sir,
How can i configure for " switching between 13/18V is automatic." to receive C-Band signals in DVBDream, since i am always getting 18V output from the tuner.
I can't see any options for switching the voltage of a dual-polarity C-band LNB in DVBDream. Maybe you will have more luck with a different application.
