DVBViewer C4 HD location?
jimfunk
Windows XP, &
DM800S
motor dish
N Wales
I cant find Channel 4 HD after a full scan in DVDViewer.
Tried manual King of Sat settings no luck.
-http://en.kingofsat.net/find.php?question=channel+4+hd&Submit=Zap
I know this channel is FTV not FTA and I should be able to get it with my setup.
Anyone have this running and maybe tell me somewhere to look or the exact settings.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi m8 ..
I seem to remember having problems getting some HD channels to scan with DVBviewer..
You could try scanning the transponer frequency with Transedit ...then exporting/adding directly to dvbviewer channel list..
If memory serves you need to have the transedit executable in the root directory of dvbviewer and run it from there...to be able to add the results of your scan to channel list.
rgds
VS
No problem for me with DVBViewer. I'm using a Hauppauge Nova HD card. What card are you using?
jimfunk
Windows XP, &
DM800S
motor dish
N Wales
many thanks, Transedit found it and updated:-thumbup
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Chances are he's using a TT S2-3200 Llew ..
I had to use Transedit on my TT card for the same reasons..
rgds
VS
Yes, may be the reason. It was also OK with my Skystar2 HD2 if I recall.
