EBSpro mobile & EBSpro
MrDish1
Delta Star
Qth:Aalten
Where can I find on this forum how to set up EBS pro Mobile and EBSpro so that they work together so that I can align the dish with my mobile.
Best regards
Best regards
I am unaware of such a dedicated topic; I can only refer to my EBSpro Mobile setup post (#22 -Jun 24, 2022).
I hope it helps you.
MrDish1
Delta Star
Qth:Aalten
Thank you satesco
it works.
Mvg
MrDish1
Delta Star
Qth:Aalten
An other question ;
got a pup-up ore massage on my mobiel.
EBSpro Crash
hase it got to doe with java ?!
java.lang.RuntimeException; Error. ?!
Mvg
MrDish1
Delta Star
Qth:Aalten
screenshot.
I have not experienced such a crash on my Android mobile. Probably the emulator...?
Restart your phone. Who knows.
stephan94
Bavaria
the best solution to present your problem in the EBSPro forum
I'll show you the way if you can't find it yourself.
MrDish1
Delta Star
Qth:Aalten
that was it, until now.
restart
Mvg
