Echostar AD 3600 IP VA Manual in pdf?
cdtronix
Supporting Advertiser
Essex, UK
1.1m Triax With Inverto Black Ultra fixed on 4.8East. 60cm Dish Fixed on 28East both Diseqc onto Dreambox 800HD. Cdtronix 1.2m Motorised with Twin LNB using Technomate TM6800 HD. Seperate Sky+ HD & Icecrypt S1500C.
Essex
Hi
Dont suppose anyone has a pdf or text file version manual for this reciver do they?
Alternatively, someone may be able to answer what im looking for, i belive this model receiver has Analouge & digital in one all built in, i need to know how to switch between the 2 types of signal as currently only receiving analouge channels.
thanks in advance :)
You can download one from -
_www.echostareurope.com/support_manuals.asp?offset=0
Silly question maybe, but you do have your LNB plug connected to the correct tuner (digital input as opposed to analogue?)
scooter123
Echostar ad3600ipva
Technomate Tm5500cip
Sky+
Technisat DVB pci 2.3 & 2.6 running on XP & Vista with Prog DVB
1.5 prime focus dish on polar mount
Invacom C120 quad LNB
T Rex cam, Diablo cam & Matrix reloaded cam
Cas 3 plus programer
Derbyshire UK
There should be 3 connectors on the back of the reciever
Digital in, Digital out and analogue in.
The dish should de connected to digital in and there should be a short patch cable between digital out and analougue in.
This should give you digital and analogue reception.
cdtronix
Essex, UK
Essex
ah ok guys, thanks for the tips. Its not my receiver, i have to go and take a look for a friend, i just wanted to make sure i knew how this worked beforehand.
that info should do nicely!
Many thanks :)
