elvis for gamma?
yeoboy
Technomate 6900 Super, !.1 channel Master,v-motor.
Samsung 42"plasma
somerset
Has anybody a tutorial to programme a gamma card using an elvis?
leez
tm 9100 tm 1500 ci dm box 600 1 m dish polar mount 12 inc acuator v box 2 cas 3 dragon diablo gamma
england
never heard of one ..wasn t elvis programmer from years ago . cas 3 i use and gammaload programe
yeoboy
Samsung 42"plasma
somerset
Yes, The Elvis programmer is quite old but it has a pheonix mode which can be either 6 or 3.5mz.
Mickha
North West
There are conflicting reports, on how to load this card, one method recommended using Phoenix 3.579 Mhz mode on a PC but 6 Mhz on a laptop, which is a new one to me.
Which loader program are you using? There seem to be at least 3 different loaders, and each file seems to recommend a different loader.
yeoboy
Samsung 42"plasma
somerset
That is the problem, I have software but no knowledge of procedure, As in loader etc.
Mickha
North West
Using a loader is quite easy, once you have the programmer set in the correct phoenix mode, and have the correct com port selected.
If you download one of the loaders, there are several different versions but all of them seem to have the same basic settings, the only 2 options you should be interested in are the Clean Card and Load File buttons.
Clicking the Clean Card should restore your card then you can simply click on the load file option, navigate to the file, you have downloaded and unzipped, and let the program load the card.
If you have ever programmed a Titanium, or MII card, before it looks very similar.
yeoboy
Samsung 42"plasma
somerset
Thanks for the info fella`s, I am going to have a go using Multi-prog, Have waited and read up on the files for the g***a cards.
kevsat
nil
nil
Hi can you tell mme how to switch elvis prog to pheniox 6mh because i can do it its only swiching to 3.5mh
Mickha
North West
Some of the older programmers had a jumper pin, on the circuit board, which model Elvis are you using?
yeoboy
Samsung 42"plasma
somerset
The model I have is called Vegas, Its possible to select either pheonix mode, Which software are you using? And thanks.
kevsat
nil
nil
Hi my elvis is version 3.5 can i use it with pheonix 6mh?
thanks
Mickha
North West
I'm not sure if this model has the capability to program in 6 Mhz mode, can you supply a picture, or more technical information?
Does it look like this?
Just been looking at Duwgati.com and I'm pretty sure that the Elvis only has 3.58 Mhz phoenix mode.
HB13DISH
Retired Mod
Middle East - Israel
The Elvis programmer is made by AD-Teknik AB
_http://www.adteknik.se
The programmer datasheet mentions that it has a 3.58MHz Phoenix/Smartmouse interface. Looks like it doesn't have 6.0MHz option
_http://www.adteknik.se/english/mp35ser.htm
yeoboy
Samsung 42"plasma
somerset
The model I have has both 6mhz and 3.5mhz, Stillm need softwae tho!!
yeoboy
Samsung 42"plasma
somerset
Thanks for your reply`s, I have multi-prog, I had hoped that someone might be using an Elvis to prog a g***a card and tell me how to do it.
Depends what you want to put on it. You use multiprog to switch on phoenix mode, then use the relevant Loader program. Do a google search for "how to program a gamma card".
You are trying to do something unusual using obsolete kit. The chances of finding someone else who has done this is remote.
When you work out what to do make sure you give us a write up :D
yeoboy
Samsung 42"plasma
somerset
You bet.Thanks anyway.
