Elvis programer
S
scooterx
hi is my elvis programer abel to program cads for seca ? or eny other sat stuff if so what rogram do i need as mp6 seems to be beeing a pain in the ass eny help to get life out of the old Card erm programer will be cool :)
PRINCE
uh::
Your Elvis can program seca card. Download the latest software from adtenik called multiprogamer V.06, you need to use the Piccard tab to select the wafercard pic and eeprom.
Regards
Prince
nobbly
Not in UK
You could also try Version 8.0.2 beta
http://www.adteknik.se/english/program.html
There is also a FAQ
http://www.adteknik.se/english/faq.html
nobbly :+
nobbly
Not in UK
Also found this software for Elvis "multiprogrammer utility" for funcard/silver card works with Win95,98,ME 2000 and XP.
http://www.tonydoe.com/MultiProg.zip
nobbly :+
J
joram7
Hi
I was wondering if you could let me know where i can download multiprogramer ver 6 you mentioned .
Im having trouble with the programs ive already got, they are so complex for an old fella like me.
any help muchly appreciated
thanks
john
[updated:LAST EDITED ON 13-Jun-02 AT 11:02 AM (GMT)]John, it is on the above link, just click and you will download it.
Rolf
J
joram7
Hi Rolf
i have tried the links you mentioned above but they are all dead!!
do you know where else i can dowload
thanks
john
No, this one works, I've just downloaded it as a test. http://www.tonydoe.com/MultiProg.zip
Rolf
J
joram7
Thank you
for some reason it wouldnt work but today doing the same thing bingo it down loaded.
Another quick question, how can i clone or copy a gold card to a gold card.
Ive tried using chipchat but i cant seem to get the new card to work
any tips.
thanks
john
lee32uk
Technomate 1500ci+ super
Triax 1.1m dish
Diseqc motor
Invacom lnb
Manchester
Hi mate
I think you just put the Goldcard into your elvis then click on 'Read' with the card that has the info on it then put a blank card in then click on 'Program'.As far as i know this should copy one card to the other.Might be best to experiment with 2 cards first to make sure.
Lee
J
joram7
Thanks lee
i tried my card in a mates encoder box
an it somehow stuffed my card. I went back to the "reprogram man"
and he reader is faulty so he coudnt get it going. He doesnt say much on how he does it but he gave me a copy of the current codes in a crd format.
I think ive got every program available and seem to have tried them all but with no success. Ive tried to erase the card and then load, but in the encoder it says unknow card. Ive heard about a loader.hex that one has to load first.
can you help?
muchly appreciate, by the way you sound you are an ozzie
cheers john
