Elvis programmer - Titanium cards v Gold card & decrypting channels
manikm
Can an Elvis Programmer be used to program Titanium cards? If so what software should be used?
Whats the diff between goldcards and titanium cards (apart from colour - lol)
Can these cards be programmed to decrypt otherwise annually subscription PPV adult services VIACCESS2 and IRDETO2 ?
If so, can the elvis proggy and titanium\gold cards be used for this purpose>?
Thanks!
The elvis works fine, you need Multiprog by TJ to set it into Phoenix mode, then Titanium Progger (both of which are in the utilities section) to program your Titanium.
The Titanium card is much more powerful than the gold and silver card, this is needed for the more complex encryptions.
They can only be used for what has been breached.
manikm
have any XXX channels on Hotbird been "breached"
if not, then what are the programmers and TITANIUM cards being used for?
sat_freak
the whole sky italia package on hotbird has been "breached"
check here to see if it lives up to ur expectations ;) ---www.lyngsat.com/dig/skyitalia.shtml
and the titanium cards are bein used exactly for the above package, in fact thats the only package they are effective for at the mo...
manikm
LOL - wish i knew Italian.
So could i not use my goldcard with this mate? (wrong chip onboard or other probs with a goldie)
If not, and i bought a Titanium card - what codes do i look for? ie. MEDIAGUARD codes? or PIDS? or what...
LOL - sorry for being a dummy newbie.
No you can't use a gold card, said so above, not powerful enough, your goldcard is only good for a couple of 1st generation packages or clearing ice off windscreens.
You need to look for Titanium files, there are loads of links here in different threads. You can definitely find a file HERE, look for S2 or Seca2 .
manikm
Hmmm....ive just dug out my elvis proggy - and i was playing around with it - I just managed to program a PIC WAFER card with the titanium files, it said card programmed successfully.
i dont have my CAM or sat setup to test it on yet - does it make sense that it programmed ok though? or should it have failed.
It won't work, the titanium files are data only and rely on the operating system pre-installed on the Titanium card.
If the data files are small enough to fit on the piccard, then it will give the programmed successfully message.
