elvis programmer
Rog1
Visit site
pj::
Hi nobby
Thanks for your help.
Can you help me with this one please
Can you send me an idiots guide to programming a gold card on elvis ie steps from 1 to 20
many thanks
Roger.
wolsty
"Satellite Expert"
VU+ Duo, Humax IRCI5400z, Sony Bravia KDL-32EX403, 1.1m Triax, Technomate TH-2600 DiSEqC mount, Sony BDV-E280 Home Cinema system, ancient Logik Freeview PVR.
Kernow
Which software are you using on the elvis?
wolsty
Rog1
Visit site
pj::
Thanks for your reply w
the programe is
multiprog basic ver3.5 firmware 1.7
OK Roger,
Get your file and unpack it into an easily navigable directory (isolate which files you require)
  1. Start up the banana
  2. Make sure the setup tab is set to the right com port
  3. Got to MP set and switch on
  4. Go to auto detect and select pic cards (you can skip this stage if you know your card)
  5. Go to Pic cards and select Gold card
  6. Press the load tab and navigate to your pic file, when found press OK
  7. Then press the Eeprom tab and navigate to and OK your Eeprom file
  8. It may be beneficial to turn off Fast Write
  9. Press Program.....and Robert is a relative. :)
    [/list=1]
