Embedded help
fazermad
Being new to all this I have been using a Dragon Cam in my Topfield TF5500PVR conax cas embedded, which has been working very well.
On the receiver I have two CI slots and another card slot which I think is conax cas embedded according to the box front. I have just ordered an M11 card and would like to know if this card will work in this card slot, or will I have to purchase another cam to put the M11 into?
Razor
Retired Mod
Ireland
If you have A conax slot, the MII card will work well.
