Error Message, while programming card
M
Mike_202020
Received my Elvis programmer this morning.......few teething troubles along the way, but sorted them via forum and search engine links...but have now hit a problem.
When I try to program a card with mp6, I get the error message:
“Programming Address 0h, Corrupt Data = 3FFFh, Expected Data = 1683h”
Get this using two different Hex files……..and it gives this error if I run “Test”.
Can anyone tell me where this error is from.....is it the programmer, or the gold card or something else?
Grateful for any help, or pointing in the direction of help, that anyone can give.
J
jim_boy
If you are using Windows XP that's your problem - otherwise its your card or programmer.
Check out the makers site at www.adteknik.se for info,additionally XP software is being prepared and should appear on the site anytime now
jim_boy
