Error: [Sky star 2] Device not started
Dzi
Sky Stars 2
Serbia
Hi guys!
I have one problem with Sky Star 2 card and PrgoDVB. I installed driver properly, but when I start ProgDVB 6.32.08 I get the error: [Sky star 2] Device not started. What this means and what should I do about it ?
Thanks in advance!
boxerman23
Neotion 3000, TH6900HD, Skystar 1 & 2, 1.2m Motorised dish with dual lnb
Bulgaria
Hi M8
Go into options and deselect any cards that have being recognised during setup, then select skystar 2 driver, or ss1 driver. give it a go and get back to me, I never had much luck with prog v6 on win xp, (v4 worked better for me) but on win 7 it works ok
Dzi
Sky Stars 2
Serbia
ok, I did as you suggested in version 6 on win xp. There is no error, but there is nothing to scan. I tried also with version 4, but there I also get same error: "Device not started". When I choose SkyStar 2 in the device list and click start the same error occurs..Other devices I cannot stop in version 4, nor disable in version 6.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Have you tried starting and stopping them in control panel........ admin..... services?
boxerman23
Bulgaria
I would suggest 1st, reinstall driver v4.4.3 then rather than load ss2 driver try BDA if no luck try WDM driver
jafar201
I have the Same Problem , I stop using ProgDvb and I am Using DreamDVB or AltDVB SkyStar2 PCI on Windows Xp Sp2 is woring Fine on both
