Evesham ALQEM37WX1080P TV
Mac0001UK
I have the above model. A fault has been identified on the Inverter Board, Tx marked 6024B709005 -06. Does anyone know where I can obtain a replacement component?
Cheers,
Mac
Moved to the appropriate section.
Who identified the fault? Hopefully a qualified TV engineer, as there are very high voltages on the inverter board of an LCD TV.
The transformer will need replaced by a service engineer dealing with that model, as it's likely to be specific to that TV. Or take the TV back to the shop you bought it from for repair.
