Express AM44 11w
pride21
Sandown Isle of Wight
hi all picked this channel up on Express AM44 its called CRBC frequency is 4106R sr1488.
nelson_b
Contributor
hi -- pride21 --
is this channel still active -- i,m testing the capabilities of a 1.2 channel master for C band and may try this sat next:)
cheers --
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Nelson ..
Just swung the dish over ..and checked this for you ..
Yes it is still active ..but signal is not as strong as RSCC
You should be able to lock it in ok ..but not sure if its doable on a 1.2
Having checked lyngsat ..its repoted to be on a 'steerable' beam ..which presumably is a steerable spot beam ..
good luck and let us know if you get it ok on your 1.2
rgds
VS
pride21
hi nelson-b yes i am still picking it up i found it stronger than the 3662R transponder.
nelson_b
Contributor
thanks for the info -- pride21-- and -- vipersan --
RSCC on the 3662R transponder. is the only one of the two i can plck up here with 1.2
very strange signal readings though on the "vantage reciever"
20% strength
94% quality
stable picture though :)
cheers nelson.b.
Kveys
Southern Finland
11W 010.JPG11W 011.JPG After problems on 80E there´s russians "everywhere" on eastern sats and now also 11W 4025R 33483. Flysat says its circular but even without depoplate signal is unrestrained here. Hope there will be more channels coming..?
Having "Indiaweek" now 66E-83E and thats why not plate on dish now. What will be 11W signals when I put plate back, 101%? :-rofl2
Retired human
11W was relatively easy for me on the 1.2m Fibo here. Glad to see the Russians everywhere, though!
Kveys
Southern Finland
H were strong but vertical xxl-Strong 96% :eek:
Kveys
Southern Finland
11W 009.JPG Quite nice signal from 4013R; 19.3 db:eek: Finally, after long finding got my own Dr.Hd F-15 today.
Kveys
Southern Finland
Quite nice 19.9 db
Retired human
Yes, a strong transponder. 15dB here on a 1.2m loosely aligned dish. In the past, the strongest transponder I had was 11dB on 3E.
