s-band
- Feb 7, 2016
Various L, S, C, X & Ka bits. 1.2m S/X/Ku/Ka Prodelin on Az-El (being refurbished), 1.8m Precision PF with SMW Q-PLL LNBs or various C & X bits
- Essex
Not a lot in UK. One test card on 42E
Spectra for the rest
42E, TP noise visible with a strong in the middle, horizontal polarisation and a weaker one vertical. There are 2, it's not just the lack of X polar rejection, they are a few hundred Hz apart.
30.9E All TP's visible. Low to high: Beacon on 13401 V, narrow FHSS cluster next, carrier in the middle is from 42E, strong carriers on both V & H spaced at 900Hz, 3 low rate (about 7-800ks) unlockable signals.
17E Nothing
7W One DVB on about 13560 V. THere used be be another, at a similar level, on 13560H.
2dB NF LNB, 1.8m PF dish.
17E Nothing
