pride21
- Jul 6, 2006
- Age
- 79
- 150cm gibertini dish,echostar 8700 analogue receiver to move dish,motor jaeger 1224,also black ultra ku lnb and esx241 c-band lnbf and technomate 5402hd ci+ super also added a Dr HD f15 receiver
- Sandown Isle of Wight
hi all here is the results of a cheap dish extension,the parts are 200mm by 100mm ali sheets and 1inch hinges cost about £20,i did not want to go any bigger because of neighbours,i admire VS for his patients and ingenuity in making his extensions but i wanted to experiment on the cheap to see if there would be an improvement on what i get now,anyway the results are very promising nearly every channel has gone up in quality from 1% to 12% and has brought in channels on border line, such as dounia on 30E which is rock solid and viasat 1,africa tv on 22W i also picked up ertu on 24W but for some reason its not there this morning,to get the results i recorded all transponders before hand then after,i recommend to try this experiment.cheers
