Mohd Sadoon
- Feb 23, 2018
- Age
- 32
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
- Oman
HDTV and HEVC DVB-S/S2/S2X+T2/C receiver for TV, smartphones and PC + DVB2ip streamer + sat finder + DVB-T2 finder + s2 spectrum analyzer + remote diagnostics
specifications:
-DVB2IP Bridge op DVB2IP Bridge options:
Open Web API...yes
Watching DVB without TV set...yes
Extension for Android Browser...yes
Application....yes
-R.A.M.F. options:
Sat Finder....yes
Spectrum....yes
DVB-T2 Finder....yes
3G/4G Finder? under development
3D R.A.M.F. LNB support....yes
Reports with signal parameters.....yes
Remote diagnostics (sending the report to the operator/installer) ....yes
Fix-it-yourself instructions....yes
-Measurements
Spectrum.....yes
RSSI.....yes
SNR.....yes
PER......yes
LM.....yes
Output voltage......yes
Signal interference.....yes
Antenna vibration.....yes
Voltage in the cable.....yes
22kHz control signal attenuate.....yes
-S.M.D.Net options:
Streaming......yes
Play content from the web link...yes
Remote control using via HDMI ...under development
One network for all devices..under development
Playing all content in the network?.under development
-Regular options:
MPEG-4....yes
HD....yes
HEVC......yes
UHD....Using streaming
DVB-S2X.......yes
DVB-T2/C..........yes
CA......yes
Wi-Fi.......Embedded, MT7601
Lan.......yes
USB...1
RS-232....On the motherboard
HDMI......yes
AV.....Jack
s/pdif......yes
ESD protection....yes
Display.....yes
Internal IR....yes
External IR.....optional
Chipset......Montage 2230M3
specifications:
Open Web API...yes
Application....yes
-R.A.M.F. options:
Sat Finder....yes
Spectrum....yes
-Measurements
Spectrum.....yes
RSSI.....yes
SNR.....yes
PER......yes
LM.....yes
-S.M.D.Net options:
Streaming......yes
-Regular options:
MPEG-4....yes
HD....yes
HEVC......yes
DVB-S2X.......yes
CA......yes
Lan.......yes
USB...1
HDMI......yes
AV.....Jack
s/pdif......yes
Display.....yes
Internal IR....yes
