finding south
den123
ddcccccc
uk
is it 12 oclock noon for south do i point the dish at the sun at 12 oclock to start thanks
satelliteman
I'd use a good compass, it's near as damn it close enough taking true & magnetic in consideration :D
SM
den123
ddcccccc
uk
so do i line the dish up pointing at the sun 12 oclock then put the reciver ar 5degree west where ever it stops the ajust till best signal thanks satman
satelliteman
First find your longitude from dishpointer.com and then follow the set up guides below in signiture :D
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
Not in summer, 1pm during summer time. (Ireland and UK )
Nobody told the sun we changed the clocks :D
As SM says, thats not the best way to do it. Best use a compass.
den123
ddcccccc
uk
so at 1oclock do i point the dish where the sun is thanks
satelliteman
Depends on how many beers you've had :-rofl2
Get yourself a cheapo compass for about a fiver :D
den123
ddcccccc
uk
i have a tm motor and a darkbox sd how can i send the motor to zero so i can start from fresh thanks
den123
ddcccccc
uk
hi guys going to try set the dish up what satelite do i set it to also what chanel do i have it on iam in exeter thanks nice day for it
5W will be a good satellite, nice strong signal, anything on 11591 V will do http://www.lyngsat.com/ab3.html
You will need to offset your mototr as per the guides first.
PS. Merged your three threads, as they all relate to the same subject.
den123
ddcccccc
uk
well guys all morning still cant find 5w i pointed the dish south 12oclock where the sun was then put usuals in reciver and sent to 5w tryed ajusting with meter cant get the signal just wundering if i pointed it in the right possition at the sun 120clock thanks for all your help den
den123
ddcccccc
uk
hi guys how do i use the compass to check the dish i have never had need to use a compass before setting it up due south thanks
satelliteman
Make sure your Moteck is at Zero and the dish is centre on the motor shaft.
Set your motor scale bracket to your Latitude, double check it's correct.
Set USALS method on your receiver.
Enter your own Longitude & Latitude.
Send dish to 5w OR select a channel on this satellite.
When the dish stops it's movement of 1.5ºW, align the dish/motor around the pole & dish elevation only.
Make sure the LNb is straight whilst it was on zero.
SM
den123
ddcccccc
uk
have done all that thanks for all your help when i point it south how do i know its in the right possition south is a big area thanks have pointed it to the sun at 12 oclock
satelliteman
forget the sun; use a compass and get your rough direction from dishpointer.com
SM
den123
ddcccccc
uk
so on dishpointer do i get 5w then point the dish in the direction then ajust with a meter thanks mate
satelliteman
Satellite: 5.0W
Motor Latitude: 50.7°
Dish Elevation: 23°
Azimuth (true): 181.9°
Azimuth (magn.): 185.3°
This is info you require for your location.
den123
ddcccccc
uk
thanks mate will give it a go again thanks den
