First attempt at C-band
I managed to get my first ever C-band transmissions today, after much tinkering and experimenting.
I think the lnb came from cdtronix - it was a cheap one to give me something to play with without costing the earth.
I managed to get 3 frequencies off Arabsat 5C at 20E using a 1m offset dish. I know thats probably not an idea set up but as usual Im using what I have available.
Frequencies logged were:
3884R 27500 3/4
3913R 8150 3/4
4054L 27500 3/4
No sign of any of the other frequencies on 20E at all.
The Mauritanian mux on 3913R is by far the strongest and gave a signal even when the lnb / scalar ring were grossly mis-adjusted
The lnb holder was ziptied to the dish, this worked adequately but needs rethinking before I can attempt anything weaker as it limits the amount of adjustment of both the lnb & the scalar rings..
All in all a fascianting couple of hours tinkering. The dish used was my 16E/23.5E/28E 1m Orbital with the Ku lnbs removed and the dish realigned.
Uh oh, B+D Workmate, probably a bit of twin flex cobbled together down the garden to power the receiver/TV combo, and snails running for cover
'Ere we go, another expert in the making. ;)
The B&D Workmate came in useful last weekend when I was playing around with 53E :-rofl2
pride21
Sandown Isle of Wight
nice one CH c-band makes things a bit more interesting.
shane77
Virgin/VU+/AzBoxMe/TM5400 and many more odds and sods
notts uk
What stb were you using to recieve the signals and exactly which lnb might have aplay myself.
Certainly does, but focal point placement is still going to be the bone of contention, regardless of the band.
Then there's the polarity (linear, or circular )?
The receiver I use for experimenting with the dishes outside is an old Vantage I have lying around.
The lnb - well I think its this kit:
-http://cdtronix.com/lnb-s/c-band/bsc421-c-band-lnbf-bsc-conical-scalar-kit
Retired human
AS, have you tried your luck on 49E? I could probably squeeze a 1.2M CM dish on my balcony out of sight, so would be interesting if you get a hint of it on your 1M Black and Decker.
Not yet, the fine weather has broken up here, and Im away this weekend so no chance of looking atm.
Retired human
OK. Would be good to hear your reception reports on this.
nelson_b
Contributor
hi - Captain Jack -
i,m going to try this myself with a 1.2 channel master -- when i get the time -- i will need to set up a temporary fixed dish arrangement --
i get a number of channels using 1.8 but i have slightly restricted view with this dish --
signal strengths are varied -- it would be interesting to try with a 1.2
regards ----
Retired human
Thanks Nelson - looking forward to reception report!
Retired human
Nelson, what C band LNB do you use on your CM? Will a CDTronix one with that conical scalar work OK or are there better options?
nelson_b
Contributor
i,m using 2 BSC 421 C band l.n.b.,s -- with the blue conical feeds
pride21 uses a -- esx241 c-band lnbf with good results -- vipersan has used both - i dont think there is a lot of difference, they both seem good - maybe it depends somewhat on the dish you use them on -
i will probably use one of them for the 1.2 test --
cheers nelson.b.
nelson_b
Contributor
hi C.J.
i tried 49 east with a 1.2 c.m. last night but could not receive anything --
i had my doubts-- as the t.p. signal strengths using the 1.8 are, on the whole not that strong --
i did however pick up channels from 57 east -- see Vipersans 57 east thread --
cheers nelson.b.
Retired human
Ah that's a shame. Thanks for checking it out.
I remember VS had an 80cm dish pointed at 49E and got a "sniff" (http://www.satellites.co.uk/forums/...-loudest-cband-source-over-uk.html#post985322) so I was hoping for more productive results on a 1.2m.
It's a shame 40E was knocked out - would have been a good source of domestic Russian channels (i.e. not horrible international versions) once Platforma on 9E shuts down in July.
vasjox
45*W - 53*E motorised 1.1m + Spiderbox HD 9000
West Yorkshire
How about 14W??? Did anyone have any sucess with this c-band sat???
Thats behind trees here - 5E is about as far round as I can go.
