Shaky1105
- Sep 28, 2024
- Age
- 59
- LG C3 OLED, No Dish Yet.
- Gilberdyke
Hi all.
I've recently bought an LG C3 OLED which has a Freesat tuner built-in. Basically, just so I've got the back-up of the ability to switch to Satellite channels if I want to, I've decided to get myself a dish sorted.
The problem is, I've bought "all in one" kits before for other un-associated stuff and I've usually been left wanting as they invariably lose out on certain features/facilities that buying individual components allows you to have. Unfortunately, I've realistically got zero experience of this type of gear as my last DIY "upgrading" was limited to fitting a bigger dish at my last house to improve the Sky reception which was circa 20+ years ago probably
The first kits I started looking at were like THIS ONE from Amazon. However, I know I haven't had to be looking for Satellite gear for ages but I'm a bit unsure about less than £50 for all that gear.....seems a bit TOO cheap for me
At this house I live in now, there's no dish installed at all so everything would have to be a new setup so no possibility of trying to copy the position of the old dish like last time.
I've read online that some LNB's won't work "out of the box" with a TV Freesat receiver (although god-knows why not ?) so I want to be able to confidently spend the £ required and know that once it's all set up, it'll work
I have plenty of WF100 cable so won't need any of that but I want to fit the dish on a pole as it'll be on a North-facing wall at the back of my garage and pointing over the flat-roof. About the only thing I've been able to confirm is that where I would like to position it (about 8' off ground level) there will be no obstructions to it's line of sight for the Astra satellites at 28.2°. I will prolly make my own wall bracket and just use a 1.5~2m length pole.
So, I would ideally like to get an 80cm dish that comes with a pole-mount and a quad LNB (Ultimate possibility of feeding 4 TV's maximum). I've got no real interest in receiving any of the paid-for channels, just the FTA stuff but would like a reasonable quality bit of kit that will give a decent signal & last a decent amount of time before it starts falling to bits . I don't wanna be spending a crazy amount of £ on it but I also don't wanna be going bargain basement gear.
Would it be worth buying a setup meter to get it perfect (if so, has anybody got any recommendations that won't break the bank) and to get all the necessary alignments correct would a compass on a smart phone be OK or are there better options out there ?
Finally, on the subject of alignments, I understand the Elevation and Azimuth settings but what exactly is Skew and how is that adjusted ?
All suggestions will be gratefully received - TIA.
##EDIT## Forgot to add, I don't mind going bigger if needed as it's not gonna be on show to anyone.
