fm transmitter from phono sockets
jon cann
www.intursports.com
Pace 2200 Sky Digital Box, cheapo LNB0.3db,
80cm offset dish in Germany.
1.35m Offset Dish, Pace 2600 Sky Digi Box. Invacom Twin LNB. In Spain.
Benicasim, Spain
is it possible to buy a transmitter that sends the audio from my receiver to an fm radio in the same house? i know that sky produced one called a gnome, but i was wondering if there is a cheaper alternative?
Humax HDCI-2000, Dragon Twin CAM 4.1, DVDO HD+ scaler, Sony LCD TV
Nottingham, UK
There are loads, just try e-Bay or Google. I have a 'Songbird' one (try songbird transmitter on Google) the sound quality of which is excellent. Most of these units have a 3.5mm jack plug as the input, to suit an iPod, so you need to buy or make an adaptor to go to phono plugs. Also the battery life is rather short on my unit as it only takes AAA cells, so I would recommend using rechargeables or a mains adaptor (the Songbird has a DC power socket on it).
David
A question about these FM transmitters that I haven't been able to find the answer for elsewhere.
I suppose that as they are so cheap that it's only a mono signal that's transmitted. Is this the case with your transmitter? If so, are there any that you are aware of that can transmit stereo?
Incidentally, I think that the Gnome uses a different sytem to transfer the signal and it's in stereo.
Interesting link David, thanks. It also explains why a lot of the transmitters are limited to below 100MHz.
Didn't know the Gnome was no longer available either. Sound quality was probably judged from the built-in speaker(s) which are usually poor on small devices.
