The trouble is, the football is not all on one satellite.
Not into football myself, but DigitalB supersports I think its called, seems to be mentioned a lot. Check out the other threads in this section.
DigitalB is on 16E and depending on UK location needs an 80-100cm dish.
I have also seen English football on Premiere Sports Portal 19.2E
and some football on D+ 19.2 E. (patched receiver), I know nothing about football, so I couldnt tell you what quality the games were.
To re-align the dish on a budget, a cheap "satellite finder" can be used,
I prefer the needle type, others prefer the beepers. These are <£10
You can also use the receiver's signal meter, which will enable you to work out which sat you are on.
and yes, there are professional meters too, but they are a lot more costly, but not normally necessary for a one off re-alignment.
If you carefully mark the dishes position on the bracketry (indelible pen), if you muck up the re-alignment, it should be easy to get it back.
To go from Hotbird 13E to 16E, you would need to rotate the dish by a very small amount to the left (from behind dish)
and down by an even smaller amount, as those sats are right next to each other with nothing in between.
