Football which package?
jasoncfc
Icecrypt S2000cci
100cm motorised dish
n.wales
Hi just set up my system i have a 100cm motorised dish, just wondering the best channels/satellites to search for, and what i may need to view the channels.
thanks
Jason
How much money do you want to spend?? The best subscription packages for football are getting on for a thousand beer tokens a year!
wod
yorkshire
the diema channels on 16e or 39e seems good value for viewing games no english audio though but they do show 3pm games and the midweek ones
the best ones sky italia and c+ 1west are quite a lot per year
jasoncfc
Icecrypt S2000cci
n.wales
I want to spend as little as possible, i bought the satellite as a replacement for Sky so looking to save money in the longterm.
I have seen cams on ebay but don't understand what they are and how they work?
Without a subscription card they dont do anything - the cam is the electronic box of tricks that read the subscription card.
jasoncfc
Icecrypt S2000cci
n.wales
ok, so do certain cams work alongside certain cards? i have seen diablo light cams and gamma cards but they are just names to me i would really like to know a bit more, i seen the other posts alot of it just goes over my head.
Some modern cams decrypt more than one encryption type.
Certain cams can also decrypt some pay tv services with modified software loaded onto them. (Only 1W these days)
jasoncfc
Icecrypt S2000cci
n.wales
I take it there are many different encription types and you choose the cam to suit the channels which you want to recieve.
How do you find out the encryption on the channels you want?
Im still unsure about the card which should be choosen?
thegilston
dreamcast 7020
motorised dish
leicester boy
thanks
Jason
i have canal sport on 1 west... No complaints, they play nearly every premier game on sat and sun or mon ( give or take one or two) so i get to watch my side EVERTON play every sat or sun afternoon live from my lounge.. Not cheap though but if you like footy well worth it..
Jason - thats one of the thousand quid a year packages!!
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Once you know which satellite your selected channel is transmitted on got to
_http://www.lyngsat.com/europe.html, select the satellite then find the correct channel and read the details regarding encryption
jasoncfc
Icecrypt S2000cci
n.wales
ok thanks, so i should check the channels then buy a cam to suit. What about the card you would need?
Decide
1) Which package you want
2) which satellite you want to receiver it off
This will give you the encryptionof the package. Only THEN can you decide
3) which cam you are likely to need.
However should you decide on Sky Italia or Sky Germany the you are advised to take the official receiver as well.
jasoncfc
Icecrypt S2000cci
n.wales
Thanks for your advice.
Im looking at digitalb which has conax encryption, what cam would you advice for this?
Mickha
North West
DigitAlb no longer show Saturday 3PM football games, or at least they haven't for some time, since they were threatened and stopped from doing so.
There are some new developments coming soon, with a new Diablo 2 cam expected to be released and rumours that Viacess 3 encryption has been cracked.
Of course these are not guaranteed to give long term viewing options but sometimes they provide quite a lot of open channels.
For the moment we still have Digi TV open, 1 West, which covers quite a few EPL games.
jasoncfc
Icecrypt S2000cci
n.wales
Hi i have the digitv on 1W do you think i should stick with that for now? Im new and chomping at the bit i want to get to know about cams is it right you need a programmer is the card just for transfering data from the pc to your cam?
Mickha
North West
If thinking about using Cams, or cards, like the Diablo 2, or Gamma card, then you will need a programmer. I recommend a Cas 3 as this can program both cams and cards.
One more thing with DigitAlb is that you wont be able to view the HD channels without one of their official receivers.
jasoncfc
Icecrypt S2000cci
n.wales
Hi thanks for your reply in your experiance is it better to use a cam or card?
Much of the time you require both. (Unless your receiver has a suitable cam built into it to read the particular card you buy).
Decide which sub you are going to buy and we will tell you what extra bits you are likley to need (if anything)
jasoncfc
Icecrypt S2000cci
n.wales
Sub? Which cam is deemed most flexible on opening different encryptions?(Mainly intrested in sport) i would also like a programmer ive seen the cas mentioned on a few threads.
Im very greatful for any advice to get me going in the right direction.
Jason
