for Technosat receiver
kevinboy
This programe is reading & Editing all channels . for Technosat receiver .
Transponder & TV Channels & Radio Channels .
Kevin
droshan
If you have TECHNOSAT 1100plus S/W than Send to me too
thanks
BiPIB
Thanks, I will try this out this evening on my technosat 6000+
hmadfai
Strong 4820 II, 1.1 motorised, Sky, Dragon, Matrix Rel. and Joker CAMs.
Cardiff
Hi BiPIB
Have you tried this software on your Technosat 6000+ and did it work?
Thanks,
H
BiPIB
Yes it seems to work.
Didn't try everything thoug...but I can see all channels programmed in my decoder.
It's a pity that it can't be used to writes ke*s in the decoder
subiamf
i m a new plz i want to know abt this
u.a.e
sir
i want to know that about the software on 2005 model technosat reciever,which i bought from abudhabi.u.a.e now its software is not working with i think,i am expecting your sonnest advice on this matter
best regards & thanking u
musthafa.a
pradeep_mah
Technosat 1020classic
KSA
can someone help me...
how can i input keys in Technosat 1020classic..... how to go inside...please tell me the procedure....
patooh
Malawi
Does this software above work on TS5500 SS II
ibe
technosat recever
P4 pc with windoews XP
Iraq
I am trying to reload the soft wear to upgrade Technosat 6000+
but ihav no luck any one to make me vavaor telling how to do it THANK YOU
ahbustami
Technosat
Jordan
need to have an updated softwere form my receiver (Tchnosat)
i'm not useing any PC i just wants to see some setup
qatar
Kevin
thanks machan
