For the Beginner in all of us
technomate 6900+ 85cm clear dish
dorset uk
Hi everybody. I've just joined your forum and my first question of what will be many is why can i pick up bonum 1 and eutelsat W4 but none of the satellites in between?
If you are in the UK I assure you that you most definitely cannot watch Bonum 1 or Eutelsat W4 - they are transmitting into central Russia & nowhere near the UK. (Unless you have Jodrell bank in your back garden!)
The same frequency block is used over and over again around the arc so if your dish is actually pointing at one particular orbirtal slot but you scan another satellite then you will get some channels appear where the transmission parameters coincide. If you give us half a dozen channels that you are getting we will tell you where your dish is pointing
dorset uk
thanks analoguesat. I am picking up KICC TV, VTV4, CNL, Rojhelat TV, Thai Global Network, Arirang TV, KURDsat and 330 other channels.
They are all on Hotbird 13E, so that is where your dish is aligned to.
_http://www.flysat.com/hotbird.php
You cannot get channels from elsewhere without realigning to another satellite, so don't deceive yourself further by scanning other "Satellites" (They are just lists of data with some common parameters!).
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
Looks like you are pointed at Hotbird 13E.
_http://en.kingofsat.net/pos-13.0E.php
Edit: Too slow.....U-zzz
dorset uk
thanks for your help. now re-tuning everything to be in the right place. Be back with another problem soon.
