Fortec Star FS4400
Michael44
Fortec Star FS4400
England
Got the FS4400 recently and am trying to use external HDD to record programmes using USB connector. Small 37GB drive works just fine, but when I put a 500GB drive onto the USB port I have problems. The drive is a Seagate 500GB but has auto power on/off inbuilt as energy saving feature. Problem is that HDD and FS4400 start 'hunting' and switching each other on and off. It is not possible (I believe) to turn this facility off on the Seagate. Suspect problem is a firmware issue in the FS but would appreciate hearing from anyone else who has experienced this and if they found a solution.
Justin
Fortec Star 4400 / Windows XP
Bolton, Greater Manchester, England
Somebody's mentioned this problem at the Digital Spy forums:
_http://www.digitalspy.com/forums/showpost.php?p=27689095&postcount=6
Unfortunately, the site they've linked to in their post, is a dead link. _http://sataid.net/forum/forumdisplay.php?f=194
If you're a member there, maybe you could send the poster a Private Message - and then share the info here. :)
Michael44
Fortec Star FS4400
England
Hi Justin,
Many thanks for your reply re the S4400 'hunting' problem with Seagate 500GB external usb HDD. I will try to get to the site you have recommended. So far I have tried a 500GB 'boxed' Seagate drive, a 500GB 'boxed' Maxtor drive and a separate 500GB Western Digital raw drive in a universal external usb 'box'. All show the same problem. I now don't know whether the problem is related to auto sleep modes, whether the FS4400 will not work with SATA drives or whether it is a drive size issue. I am just about to try it with a 160GB ATA/IDE drive in the external USB enclosure. Fortec Star Tech Support are very good at bouncing a reply back telling you are they 'looking into the problem' and asking for serial No's, software revisions etc but that then seems to be the extent of their support. Not good I'm afraid,
Thanks again'O'-red
Real65
FS4400 and old sky dish
Chadwell Heath
Hi Micheal,
I also have a fortec star fs4400.
can you please help, I have tried to download software upgrade by usb, but the reciever just has ASH on the display. Can you help?
Justin
Real65 said:
Hi Micheal,
Have you tried to reinstall the official firmware from the Fortec site? Can you still access all the menus on the box?
Real65
Chadwell Heath
No the box just displays ASH. When I switch the box on it says ON then goes to ASH, nothing displayed on tv, no sound or menu.
Justin
When did it start doing this? Have you still got your sales receipt?
Real65
Chadwell Heath
Hi Justin,
I was told by Fortec to return unit to distributor and I have since recieved a brand new one as they reckon the unit was still under warranty.
Does anyone have any idea how to get to the nagravision on the remote, I have some keys I will like to input.
Thanks.
Nagra keys? They must be an endangered specied nowadays :D If they are for anything other thatn Digi+ on 1W you are wasting your time.
Real65
Chadwell Heath
I take anything I can get at the moment dear wife is nagging too much.:mad:
:-rofl2
Get yourself a set of wireless headphones - you can retreat into your sat tv world and ignore the missus :D
Real65
Chadwell Heath
