Fortec Star lifetime diamond ultra DVB-S & T
birkenhead
dbox2, fortec
hi,
Just been given a brand new unit, but haven't got a clue what to do with it!
Try to find a little info it has a embedded DVB-S & DVB-T but no card slots, did a google but can't find any info on this unit!
The question I'm asking is can this be patched & how anyone got a tutorial & patches & tools etc...
Any help will much be Appreciated
It will do FreeView DTT (if your local transmitter is carrying it) and satellite.
FortecStar have pretty good hobby support, although dunno about this model
Try here:
_http://www.al7bar-soft1.com/
birkenhead
dbox2, fortec
Try here:
thanks for you replay!
Not must luck on this site can't find the boot.file!
_http://www.al7bar-soft1.com/FTA/LIFE%20TIME%20DIAMOND%20Ultra/LIFE%20TIME%20DIAMOND%20Ultra%20MAIN.htm#Softwares
So if anyone out there as this please contact!
The search continues!
Some boots on this site for Diamonds -
_www.geocities.com/nhfs49/FortecstarBoots.htm
birkenhead
dbox2, fortec
Thanks for replay...
Can i use Lifetime Diamond boot file on a Lifetime Diamond Ultra?
are they the same chip set!
If i flash it with this will it work or screw the unit up!
DSM
Technomate 1500CI super, 78cm solid dish, 0.2db LNB, HP Pentium4 PC with XP Home. Foretec Star Lifetime Diamond (more trouble than it's worth)
Merseyside
Try Yahoo Groups and join Fortec users you may get some advise there. I patched ny receiver using ALbar7 software which did work, but have had no end of problems and use the Lifetime Diamond only for DVB-T (freeview) and it's not much good for that!
Tell me if you have any success:-ohmy
