Freesat and fta satellite receivers
wium
C and Ku
South Africa
What is the main difference between Freesat and FTA receivers.I assume it is in the tuning capability ,however,can one get a FTA receiver that incorporates Freesat and HD.
ralphmagno
naples italy
hello,
FTA refers to free to air receivers any transmission that is free you can receive if the signal reaches you strong enough.
if a free to air signal reaches europe with a 60 cm dish it may take a 4 m dish to receive the same signal in south africa.
HD refers to high deff. transmission. high deff uses 720 lines or more to bring a better picture.
most high deff uses mpeg -4 or h224 and most hi deff can receive both standard and high deff.
freesat thats another topic there has been some confusion on this topic.
some channels on the satellite may be encrypted ,require a card but till not require a monthly payment.
tv 5 uk or channel 5 is a free sat channel. it needs a decoder,a card but no monthly subscription fee.
bbc 1 bbc 2 and itv channels are free to air and require any receiver but you need a big enough dish to receive this signal.
the tuners are all the receivers are the same.
they will tune the 2nd in frequency of 950 mhz to 2150 mhz.
hope this helps a little
ralph
Freesat is a system whereby the main Free To Air Channels pay for a fixed EPG slot and have associated with them 7 full days Programme Info and features permitting easy recording (like Sky+) with PVR enabled Receivers.
Freesat Receivers also have a non-Freesat mode which enables all available Free To Air Channels to be received, but with Now & Next EPG Data only. They can, as with a generic FTA Receiver, be put in any order you like.
The Channels Ralph refers to above that are Encrypted are not Freesat Channels, but FreesatfromSky Channels! So there is indeed confusion - the unfortunate use of the term Freesat by BSkyB! On there, there are a handful of Channels which are Scrambled but don't require Subscription (often referred to as FTV or Free To View). Any valid Sky Viewing Card permits getting them.
But going back to Freesat itself, which is run by a consortium led by BBC/ITV, everything on there is Free To Air and requires no Card. Five is available and does not require a Card ............. there are Encrypted versions of Five, used by BSkyB, but fortunately there is an FTA version that was introduced especially for Freesat.
So don't worry - Freesat gets you all BBC, all ITV, all Channel 4 (apart from HD, but that appears to be "coming soon"), Five (but not Five US or Fiver) plus many more.
As you are in South Africa, a Freesat Receiver is no use to you anyway, as it refers primarily to 28E. Some Freesat Receivers have DiSEqC and multi-sat features, but the Freesat EPG is obviously not available off 28E and what you basically have left is just a generic FTA Receiver.
wium
C and Ku
South Africa
Both replies are very comprehensive and greatly appreciated.Thank you.
