Freesat problem - Astra 2A only?
vt_perplexed
Communal Sky Dish
New Build Apartment (1997)
Central London
London
Hi guys, I can't find the answer to this anywhere on the web and hope you can help:
Problem:
I can only receive the channels listed as coming from Astra 2A at 28.2°E but not the others in the group (e.g. Eurobird 1 & Astra 2B/2C/2D).
i.e. I can only get some channels but not those on Astra 2D like BBC HD, BBC1, ITV etc..
Some background info:
> I live in a central London flat and use a communal Sky dish (I guess it must be pointing at 28E since I can receive Astra 2A - If these channels are available from another satellite maybe I'm wrong).
> I use the new Humax Freesat HD receiver (FoxSat-HD)
> Freesat tuning did not work, I only found the channels from Astra 2A by performing a full scan in the manual tuning options.
> Software updates do not work (presumably because I can't access Eurobird 1)
> Postcode search always turns up as Postcode Invalid (presumably because I can't access Eurobird 1)
>The channels I can receive are all those listed on this page: http://www.lyngsat.com/astra2a.html (i.e. the Sky channels and the Welsh freesat channels like S4C)
Any advice/insights or guesses would be greatly appreciated ! Many thanks in advance.
satelliteman
Welcome,
I would first test your Foxsat receiver on another stand alone dish
Also ask others who share the communal dish if they are receiving ALL channels inc BBC & ITV which are on LOW band 2D
Freesat EPG is on E1
SM :)
fevgatos
NanoXX 9600 IP,TM-6900 HD,Virgin Media V box,Diablo cam h/r 2,3,Irdeto 2,Matrix Reloaeed,Cas I nterface 2+Plus, 2 Funcard 4,Satlook Digital NIT,Lacuna broadcast identification,1 m Dish Orbital 1.0m, Lnb Syntec 2;Thousand platinum edition,sat instal,,
BRISTOL.UK
Hi vt_perplexed first you should check you quality signal ,and if your signal is the best quality then you locking on 28.2°E ,and do search again turn on network search ,i thing all channels you can get after ,Regards fevgatos
vt_perplexed
Communal Sky Dish
Central London
London
Thanks guys.
1. The Receiver is working fine
2. I have not yet been able to find anyone else in the block who is using satellite.
3. I'll check the quality tonight - and will let you all know how it goes...
vt_perplexed
Communal Sky Dish
Central London
London
Hi all - it has taken 1 year but the problem is now resolved. The issue was with the shared hardware (satellite dish and equipment) for the entire block of flats. It was faulty/poorly configured. We have just had a company install new equipment and everyone in the block of flats now has great reception. Best regards.
Crumbs that took some time, but glad you've got it sorted at last.:)
