French Infra Red
leespencer
1.2m Dish with twin Chess LNB. Humax Foxsat HDR. Laptop computer.
Andalucia, Spain
Hi, a newby here, my first thread in fact.
I'm having difficulty getting a hard wired Infra Red extender system to work with a French Canal Plus box, the one they call Le Cube.
I can get the Sky box next to it to work OK but the french box will only respond to maybe 1 out of 20 remote commands.
Could the Le Cube box be using a high frequency Infra Red system?
Thanks.
It's possible that Canal + box doesn't use standard IR commands (I thinks it's called IRDA? or possibly IRDA is the one that isn't standard??).
I recal quite a few years ago that here was box that didn't use the standard style of commands and as a result you coldn't use a multi device replacement remote control. I don't suppose that you use a multi remote control by any chance?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Thanks.
Which remore extender exactly are you trying to use?
As it seems likely that you are correct regarding IRDA, since it's a Pace box and using interative services, similar to some of the older C***e T***west receivers. There are remote extenders available apparently.
leespencer
Andalucia, Spain
Thanks, the remote system I was trying to use was similar to the Xantec stuff. Any ideas where I should be looking for a remote extender that will work?
