emul
- Jun 30, 2006
- Age
- 55
96cm dish, dual LNB, two FTA receivers - Visionet & SAB FTA.
Analog aerial VHF / UHF.
- Ireland
Greetings to all, I've reviewed the different forums and if this is the wrong one - my apologies. I am having an issue with my setup I hope you can assist with (i have reviewed other postings but can't find similair issue):
Setup: 96cm disk with dual LNB feeding a SAB Explorer & Visionet F7100.
Signal strength is excellent, picture perfect
UHF & VHF aerials joined on masthead coming via one cable to signal splitter in attic (one antenna - two outputs)
Have run cable from aerial signal box into ANT IN on above recievers.
Visionet feeding one room , SAB other - both via single cable.
Problems:
1. From Aerial - RTE 1 / 2 / TV3 / TG4 - very poor signal (teletext rubbish) - previously ok
2. From Aerial - BBC 1 / 2 / ITV / CH4 - gone - not a major issue as have all but CH4 on FTA - but would like CH4 back.
3. On either TV I am picking up signal from other FTA box (good I can see what kids are watching) - but should this happen?
Any ideas? Thoughts?
Problems:
